ORIGINAL: kf6bpa
Yes I tried every USB port on the computer all 6 of them and the same responce on all of them. I get the little beep beep when I connect and disconnect and One time I thuoght I hade it licked when I pluged it into one of the ports on the back anf the little screen poped up and said new hardware found and listed the controller but that was the only time I seen it. I got all excited for nothing.[&o]
Ok, so when you plug in the USB cable to your PC and use the Game Controllers tool, you do not see "Hangar9 FS One v1" appear in the list? If the Game Controllers tool does not see it in the list, neither will FS One.
If you are seeing "Hangar9 FS One v1" appear, you should also see a status of "OK". If you don;t get an OK status, FS One will not be able to read the device.
The other possibility is you can see it in the list and the status is OK, but the axes don't move. Is this what you're seeing? If so, exit the Game Controllers tool, disconnect the USB cable from the computer, plug in your Tx or the TacCon into the USB box, and then plug the USB cable back into the PC. Can you see the axes move when using the Game Controller tool at that point?
