RE: Avistar assembly question
Pete, Great job on your maiden!!.... Loads of tips on how to get the fuel out, and it
should work... It's worth a try...... I try to paint/thinned epoxy the hard to see tank
fuse area to go along with the drain holes to catch any leaking tanks as soon as
possible.. Again Good job on your flight!!
Also on tanks that are in harder to install, or for me just about all my tanks, after
tank assm. I go ahead and fill them and even if it's just from the pressure that you
can build from the fuel pump and a blocked vent, check for leaks before installing...
