dumb question...
The reason most beginners do not use rudder in flight is because the aircraft are designed (excessive dihedral) to couple roll induced by the ailerons to the yaw axis automatically. If you build a trainer without dihedral, you will soon see the need for rudder (yaw) control in flight.
