RE: E-Flite Park 25 Motor shaft replacement
The clip usually goes on the shaft end that protrudes through the base of the motor that's attached to the motor mount. It's designed to keep the shaft from pulling out of the motor when the prop is connected to the spinning end. There should be a groove in the shaft.
