RCU Forums - View Single Post - REAR DIFF
Thread: REAR DIFF
Old 10-18-2006 | 09:20 PM
46u's Avatar
46u
Default RE: REAR DIFF
If you are replacing the ring gear I would replace the pinion as well. You want to shim the diff and pinion gear together as close to each other with out bind and have just a little gear lash. I shim both my pinion as well as my diff.
