RE: HELP!!!
set it back to stock settings on motor with all screws... Its in the first few pages of the manual. From there, since its your first nitro, start you motor and face it against a wall or sit it on a box the where the wheels dont tuch anything. If it stalls, turn the main needle a 8th of a turn clockwise, and try again. Use small amounts on the needle. Do not go in more than 1/8th turn at a time. If you have to leave the glow plug ignitor in it to keep it from stalling right now, that is fine. I would't in more than half a turn right now you will tune it more as you break in.
Once it will stay started, Idle it through 2 tanks, if you have a temp guage keep checking it to make sure it doesn't go above 200 to 220 degrees. Let it cool down between the tanks for about 10 to 15 minutes atleast. After that, put it on the ground and run it around but between 1/4 to 1/2 throttle for one tank. Let it cool again than do the same thing going between 1/2 to full throttle. Once this is done, you are ready to tune for running.
When tunning for running, concentrate on main needle till you get that strait. Just turn in 1/8 turns till its running smooth and blowing smoke throughout the throttle. Smoke is good. If you dont have a temp guage, get one. They are your best friend if you plan on running nitro. I check mine all the time when I am running. You want the temp to average between 200 to 220. If you go much higher, you could overheat if you start doin alot of highspeed passes. A car runnin at 220 can easaly hit 250 or 260 after a few highspeed passes.
Once you get this set, start your car and pinch the fuel line and listen, the motors rpm's should increase a little and then stall... should take about 8 secounds to stall. If the rpms increase alot turn the low speed needle clockwise (the one where that linkage conects to your carb from you servo) Use small adjustments and try again. If rpms do not increase and motor just stalls in less than 8 seconds turn it counter clockwise to richen it. Keep trying and doin this test till it sounds right.
After all this, start you motor again and adjust your idle screw with small turns till it idles well. You will probably have to turn it counter-cloackwise to slow it down at this time becuase of the adjustments to the low speed needle.
Once all this done, just run though test again to make sure everything adjusted. Tune your engine like this every day you run because weather conditions really effect nitro motors.
If this wasn't your first time, I would heat cycle the motor, but this way is best till you get the hang of tunning. PM me if you need more help.
