RCU Forums - View Single Post - engine starts backwards
Old 10-19-2006 | 01:27 PM
NM2K
My Feedback: (14)
Default RE: engine starts backwards
ORIGINAL: skiman762
I don't see cooling being an issue there will plenty of air flow regardless what direction it moving
Pusher engines do overheat more often than tractor set up engines, unless there is a shroud placed around the propeller AND engine. It is a fact of life, believe it or not.
The heli boys used to (may still) have a special prop nut and a special extension for their starter motors available. Ducted Fan folks too, now that I think of it. Using the correct one of these set ups, you could reach in between the rudders and electrically start your engine. Good luck.
