RE: MAN Plans Purchase
Mark.....
You had better waif some more. I have four different copies of plans for the Curare' here. The M.A.N. version has some problems. Many times the problems deals with wood, if fractional or metric thickness, they seem to interchange on that plan. More problems with the areas alotted for the landing gear, for some odd reason the gear is longer in the extended position than the retracted. It seems to shrink about 1/4 inch in the two positions. In round figures the M.A.N. plan is not all that good nor accurate, nor cheap.
I just completed a rigid gear version of the Curare, and it smacked the pavement vertically at full scream. Am on to another one once I locate some metric thickness wood again.
Wm.
