RCU Forums - View Single Post - PAW 19DS in OTS Ringmaster
Old 10-21-2006 | 09:23 PM
SGC
Default RE: PAW 19DS in OTS Ringmaster
Sounds like its undercompressed or lean- undercompressed needs a richer needle to maintain a smooth run. I find upping the compression and leaning the needle till the revs max and hold then back off the compression-just ie 1/8th turn then open the needle a little generally gives more consistant runs , keep opening the needle till it flys your pattern.
Stewart
Oh my exhaust tends to run blackish due to the higher power settings
