oohh ok. I thought the drawing had the radial mount in it. I would use the radial mount if it's strong enough for the aluminum stand off's. I thought the Taurus guy said that the radial mount was not strong enough for the small point of contact of aluminum stand off's.
Using the 6 5/16 dimension, I would need 1 inch stand off's to clear the 7 1/4 distance of my Edge.
ORIGINAL: Silversurfer
The dimensional drawing shows the engine without the radial mount. The figure I gave of 6-5/16" includes the radial mount. Are you inferring that you do not want to use the radial mount?
