RCU Forums - View Single Post - Cen GST 7.7 Problems. Need Help :(
Old 10-23-2006 | 08:16 PM
aluminum crusher's Avatar
aluminum crusher
Default RE: Cen GST 7.7 Problems. Need Help :(
ORIGINAL: Ghaligan
Ok i don't understand this. This engine is totally different from the Cen Genesis Limited Edition Truck. After i broke it in the 6 tanks, and changed it to the prefered settings, it's overheating rapidly. If it's too rich, i got a problem. If it's too lean, THAT's worse. If i run it lean, the temp climes over 400 degrees in less than 10 seconds. Even with the High Speed Needle out. If i try leaning out the Low Speed needle with the High Speed Needle in too, same thing. It goes over 400 degrees immedately. If i richen the High Speed Needle and bring IN the Low Speed Needle, it does it AGAIN. If i Richen the High Speed Needle and, the Low Speed Needle, she won't start. If i mess with the Idle, well it idles fine no matter what. Here's another problem. The Fuel that goes into the Carb does NOT stay in the Carb. As soon as i give it a pull, just ONE pull, the fuel immediately escapes the Carb and back into the fuel tank. This happens rather the Low Speed Needle is in, or out. I can't seem to find that setting for the best proformance without climing over 400, like my Cen Genesis LE is. You know what's the worse part? I've been doing this now without the Body on. So i'd only imagine the situation much much worse once i start placing that on. If anyone could reply for help, that would be great. Thanks everyone. I've been at this for 2 days now, and the bones in my hand are ready to snap from pulling and pulling. Not saying i hate the pull start, in fact i rather deal with pull start than Roto Start.
Maybe this will help I had an over heating problem with my ofna GTP 1/8 scale over heating after the break in process. The owner at the LHS told me to stop using that blue T fuel because of the blue gummy residue it was leaving on the piston, and to try O d fuel but none was in stock at the percentage that I was using ( 30%). So I bought a bottle of 30% Trin fuel readjusted the carb a little bit and the over heating was no more available. I also used a cold plug thru break in & for fun about 3 gallons of fun.
