RCU Forums - View Single Post - New Taurus 3.2
Old 10-23-2006 | 11:48 PM
  #34
T-one's Avatar
T-one
Default RE: New Taurus 3.2
AZHAR, No longer making the 42, no need for it when the dimensions are the same as the 52 except it was 2 ounces lighter. Therefore throttle control is necessary.
JOEAIRPORT, the adjustable radial mount added too much unnessary weight, not practical.
Every one that I have seen that needed extra length uses a very simple solution, use a hardwood 1" dowell cut to the proper length and drill a hole thru the center,VIOLA!! any size spacer you need and CHEAP to.
The reason for Taurus not using a 4 point spindly stand off is that the engine developes a lot of torque and in testing years ago actually watched the engine twist the stand off.Very unsafe condition. Ask any engineer which they would prefer, a 4 point standoff or a full contact 5 point radial mount. In our case, there is no discussion on the issue.
