RCU Forums - View Single Post - GP Wagstaff Extra
Old 02-11-2003 | 03:50 AM
monkeyhead
Default GP Wagstaff Extra
The wing tubes should fit SNUG, but not tight. Example: You should not have to use the fuselage as leverage to remove the wings from the tubes, but not loose enough so that there is a significant amount of movement when the wing is mounted on the tube.
