RE: Jet-Tech Maverick conversion
You can use the regular inlets, cut them about 2 1/2 inches from the leading edge, use the tanks to form a path to the front of the turbine. Wedge the tanks at the front between the fuse and the inlets, make two brackets to hold the back of the tanks in place. I saw this on Ray Blairs plane and according to him it worked great. This is the setup I am using on mine.
