RE: New Taurus 3.2
Well here it is 1:15a.m. eastern confusing time.
Camss69. the advantage is the single bolt in my opinion. But since most props have a 10mm center hole you still have to drill it out for the single bolt hub. the 6 bolt has a 10mm pilot, but you have to drill 6 little ones.We try to answer the needs of the consumer.
Pretty darn soon on the headers.
Silversurfer, yup OK to use the 1"dowel. Or if you really want to maintain the solidity of the radial mount, cut a donut shaped ring the desired thickness the same diameter as the mount(4")
We're trying some new ideas with the twins, and it is our policy not to release anything until it
meets or exceeds our initial specs.
Taurus Engines. Use it, don't abuse it and like TKG said,your grandkids will have a great engine.
Please don't run the Taurus @ 32, or 40 to 1. We don't care what the field experts say. We designed and built the engine, the field experts didn't
Thanks to all for purchasing a Taurus and your confidence in our product.
