RE: Fliton Rogue undercart problem.
Hi Flitonusa, thanks for the reply.
Here is a photo of the problem.
It actually looks like the angle of the mounting part of the legs is at the
incorrect angle as I had to remove material from the fuselage sides
in order for them to screw to the plate correctly.
As you can clearly see this fault has made the undercart completly useless.
Best regards.
