RCU Forums - View Single Post - NOT SURE IF ENGINE IS FROZE UP??
Old 10-26-2006 | 08:51 PM
StoneDeaf
Default RE: NOT SURE IF ENGINE IS FROZE UP??
Thanks for that Piper.
Do you think more then likely the engine is just gumed up and there is no rust? I did not drain the little bit of gas that was in it the last time I used it 2 years ago. I know nobody knows if it is rusted from not looking at it but might know for experience and if I get the carb loose it should run like it did when I last used it? Thanks for the help.This really is helping me
WOuld maybe a the heat from a hairdryer being put on it loosen it too?
