RCU Forums - View Single Post - T-Hawk Battery Replacement?
Old 10-27-2006 | 06:44 PM
Fliprob17's Avatar
Fliprob17
Default RE: T-Hawk Battery Replacement?
ORIGINAL: WECKY
ok I have a battery from batteryspace.com for my Easystar It's 7.2 v1100mAh with an deans adapter,can I use that in my T-Hawk(see above)?
As long as the stock battery for the T-Hawk was also a 7.2 volt, you should be fine.
Also,from Batteryspace I have a smart charger to charge the above battery can I use it to charge my T-Hawk Batts.?I see that I can't charge the 600 mAh Predator and Skyseeker batteries.Thanks don't mean to be a pain.
As long as both batteries are the same voltage, 7.2, and both are the same type, NiMh's, it should work fine. However, if the charger is specifically for the 1100mah size, you may have to pull the 600mah or 900mah batteries off early to avoid overcharging. Unless it has some kind of setting to program in the battery capacity. You will have to put a Deans plug on the charger if it did not come with one, and you will also have to put deans plugs on your old batteries.
