RE: 3W Service?
i found a crack in the corner of the black carb block next to a screw.... sealed it with high temp silicone sealant and i'm sucking fuel again! i will order a replacement part as i have no idea how long this fix will last... only problem now, is that it wouldn't start!? carb is leaking fuel, pulled the spark plug to make sure it was sparking, even changed to a new spark plug and it won't start! geez. needles are set back to factory settings, and it can't even get a small pop out of it.... im recharging my ignit batt right now to see if that'll help. grrr i may just have to send it in after all
