ORIGINAL: Flyboy Dave
Yes, it could be pulling air in from the front bearing....you might have to live with it,
or...put a sealed bearing in the front....if that is the case. [
Loosen the headbolts using a cross pattern, and tighten them back down using a
cross pattern....just to eliminate a head, or liner leak.
FBD. [sm=regular_smile.gif]
ok I checked the head bolts, if it's not the carb I guess its the bearing. Thanks for the help
Frank
