Tower .75 won't stop ??
Old 10-30-2006 | 07:15 PM
Default RE: Tower .75 won't stop ??
Just a point.....DOINT BUY A TOWER HOBBIES ENGINE>>>>>>EVER
Old 10-30-2006 | 09:13 PM
Iflyglow's Avatar
My Feedback: (79)
Nads,
If you think you have a better running engine. I would like to hear about it. I will put mine against any modern glow engine you can come up with. How many glow engines can you run 10 gallons through them and never dead stick.
Old 10-31-2006 | 08:07 AM
speedster 1919's Avatar
Your low end is just a little too rich. About a 1/8 turn should take care of that. Prove it to yourself and pinch or pull off fuel line . I'll bet it will idle for awhile. Most front bearings leak air a little . Too good of a seal would create too much heat and friction. The air is passing over a puddle of fuel inside of engine. I do this before jacking with other carbs.
