Yea Dick the HP numbers are probably a bit off, but the RPM should be about right.
With the reducer you could gear the engine to operate at its max HP, no matter what the real number is, its still max.
If a pipe helps an 80 single think what two would do on a twin
If you were real crafty you could run both exhausts in to a single 80cc pipe
