RCU Forums - View Single Post - Glassing Avistar Wing Joint: How To.
Old 10-29-2006 | 08:52 PM
bigtim
My Feedback: (13)
Default RE: Glassing Avistar Wing Joint: How To.
checked the manual, I have a NEXTAR and they are close in const.
really there is no need, really you would be adding weight instead of helping your self .
if you are wanting to do it for a lesson on how to do it, then remove the covering only to where you need to apply the glass aprox.1" to2" from center seam.
mix some 30 min epoxy thinning with alcohol about 10% so it flows easy lay glass over the seam so it overlaps aprox 1" on each side or more if you like, and saturate glass so the fibers are wet you don't need to leave too much extra use a card, either credit or playing, to spread epoxy smooth thats pretty much it the glass provides the strength so you don't need to over load the glass with resin it just adds extra weight.
