RE: Need Help.
Thank you for your response.
I have owned high end RC's when i was much younger. It has no servo's, or speed controllers. It's basically a circuit board located center, and connections coming from it. I checked all connection's, and everything seems solid. Motor's are not bad, because we have reverse power, and steering. It get's nothing for forward. Not even a try. It's almost like it could be in the controller, and not the car. I will pull the top off, and take some pictures. Warranty in this case is pretty much useless. I thank you for you input. It is much appreciated.
