RE: help with the topflite dc3 construction
We're not sure what the difficulty may be. When assembled per the plans, the wing sections don't have any particular difficulty at the center-to-tip panel joints. You may need to carefully go over your components to see what may be causing the tip panels to not align properly with the center panel.
Please check each against the plans. You should be able to see what the difficulty may be.
