RE: Need some info on a HD DuBro Pull Pull set up
This is all I got. The key is to loop it around one more time through the ferrel before crimping. So you will have three passes of the cable going through one crimp ferrel.
I attached a really lame sketch. The thick black line is the ferrel. The thin line is the cable. Hope this helps. The turn buckel is also shown. I needed to enlarge the pic when I went back to view the post.
