RE: Tower .75 won't stop ??
Your low end is just a little too rich. About a 1/8 turn should take care of that. Prove it to yourself and pinch or pull off fuel line . I'll bet it will idle for awhile. Most front bearings leak air a little . Too good of a seal would create too much heat and friction. The air is passing over a puddle of fuel inside of engine. I do this before jacking with other carbs.
