RCU Forums - View Single Post - Problem with Ram CP ECU
Old 10-31-2006 | 03:50 PM
Angus McDonald
Default RE: Problem with Ram CP ECU
RCMIGPILOT, I have a ram 750 cp ecu that I might want to part with, The turbine has 43 cycles on it, I aquired it a while back, never used it but will more than likely upgrade the ecu before I use it. I did bench run it twice and it ran fine
I have no idea what they are worth, I can send pictures if you like, I'm in Canada but live right by the boarder (International Falls MN) and have a USA mailbox to make things easy.
Angus
