 Problem with Ram CP ECU >
Old 10-31-2006 | 09:12 AM
My Feedback: (26)
Default Problem with Ram CP ECU
I have an air start Ram 750 with the CP ECU that is sending 6 volts to the plug. Can anyone help me with this?
Old 10-31-2006 | 11:05 AM
ghost_rider's Avatar
My Feedback: (20)
Default RE: Problem with Ram CP ECU
Call Andy at Electrodynamic and he will fix you up. He made the ECU.
Orders: 1-800-337-1638
Info: (734) 422-5420
Fax: (734) 422-5338
Old 10-31-2006 | 12:04 PM
My Feedback: (26)
Thanks Ghost, I posted this after I called Andy. The ECU is on the way, but there is a chance, depending on what is wrong, that he won't be able to fix it. Apparently some of the components he used to make it are no longer available. If that happens I'm going to need a new ECU .
Old 10-31-2006 | 12:32 PM
Call Carlos, he might have one.
Old 10-31-2006 | 01:33 PM
My Feedback: (26)
If you have one bring it with you Sunday. Even if the other one is fixable it would be nice to have a back up, I have both a 750 and a 1000 that use the same ECU.
Old 10-31-2006 | 03:50 PM
RCMIGPILOT, I have a ram 750 cp ecu that I might want to part with, The turbine has 43 cycles on it, I aquired it a while back, never used it but will more than likely upgrade the ecu before I use it. I did bench run it twice and it ran fine
I have no idea what they are worth, I can send pictures if you like, I'm in Canada but live right by the boarder (International Falls MN) and have a USA mailbox to make things easy.
Angus
Old 10-31-2006 | 07:47 PM
Terry Holston's Avatar
Is that ECU even legal to use at an AMA event in the USA with out the 2 second failsafe?
Old 10-31-2006 | 08:25 PM
As long as his radio is set to shut the turbine down instantly on fail-safe or within 2 seconds!
