RE: Fliton Rogue undercart problem.
Hi there,
Sorry about the delayed response, we were at the Tucson Shootout all last week. I do see the camber in the landing gears from the front view, but it is hard to tell what the problem is without a side or 3/4 view. Your gears should sweep back when attached, which I cannot make out in this picture. To attach the gears, there is small opening beneath the covering on both sides of the airplane. Did you drill on the correct spots on the gears so they will line up with the holes in the gear plate?
I am not quite sure what you mean by undercart. There is no undercart near the gears, they simply slide into the allocated slots along the side of the fuselage.
Looking forward to hearing from you some more to get this resolved....
