RE: Balancing props?
using mostly wood zingers in the 11 to 13 inch range i do use a magnetic prop balancer they are pretty close if not I just spray the light blade with some clear lustre coat now you have to wait for the solvent to evaporate just a minute or two and recheck it might need an other short shot I can get a perfect balance no sanding if over done just give the other blade a short spray quick easy
martin
