Balancing props?
Old 11-01-2006 | 01:08 PM
Flyboy Dave's Avatar
My Feedback: (21)
Default RE: Balancing props?
I carefully balance all my props and spinners....always have. The props need to be balanced
for proper trouble-free operation.
Try flying a full scale airplane with an unbalanced prop....
....the instruments would probably vibrate out, and fall in your lap. [X(]
FBD.
Old 11-01-2006 | 02:15 PM
RVM
I use the DuBro balancer to check the balance.
I use clear fingernail polish to balance out a prop.
On my Saito I can tell if a prop is more than just a little bit out of whack.
Old 11-01-2006 | 06:07 PM
I recently bought a bunch of 12 inch APC props (12x4, 12x5, 12.25x3.75) and was a little disappointed how out of balance a few of them were in comparson to the ones I bought before. I expect to do a little work but this was more than the usual balance job. One of them I decided not to even use but makes a good mixer. Anyone else having a similar experience lately with APC or any other brands? I might start taking a finger balancer to the hobby shop. It seemed like balancing the inner half (hub) was the most problematic on this batch. I might buy a few Graupners and giving them a shot next.
Old 11-02-2006 | 06:51 AM
If you bought them from a LHS, and they're that badly OOB, return them. When I'm going to buy props, I always take a little Dubro teeter balancer to check them.
Dr.1
Old 11-02-2006 | 12:20 PM
MJD's Avatar
MJD
ORIGINAL: rustypep
With APC, yes. Just a question though - is your balancer centering the prop via the molded recesses in the hub, or the drilled through hole? Those drilled holes are a sore point, they are all over the freakin' map and should never be trusted.
MJD
Old 11-03-2006 | 08:25 PM
  #31
Nope, I used the recesses but that is a good point. I hate to stand there and check them at the store but that is better than the alternative.
ORIGINAL: MJD
MJD
Old 11-04-2006 | 07:45 AM
  #32
speedster 1919's Avatar
Rusty Maybe you bought the bottom of the barrel props. Someone does because some guys return the bad out of balance ones.
Old 11-08-2006 | 11:36 AM
  #33
MJD's Avatar
MJD
ORIGINAL: rustypep
It is now standard practice for me on all sizes to ream the hole out oversize, then center the prop via a bushing fit into the rear hub recess. After talking to APC and having them admit their hole drilling was not always perfect (no, really?) I made the decision to go that way across the board. Otherwise I like their props. It's easy if you have a lathe.. but more troublesome if you do not. It does not take a lot of offset from center for an otherwise properly balanced propeller to shake like the dickens. Every few thou is x amount of mass removed from one side, and added to the other.
MJD
