RE: WHAT'S WRONG WITH NITROPLANES.COM?
I'd consider cutting the CA hinges and using those nice dowel type hinges with the built in hinge points instead.
That should give you the desired travel, but you would be able to reduce the gap.
As Gotsky stated, you'd want to seal the hinge never the less.
