RCU Forums - View Single Post - Fliton Rogue undercart problem.
Old 11-01-2006 | 06:52 AM
DV1
Default RE: Fliton Rogue undercart problem.
Hi again,
I have attached a couple of better photos for you.
When I say undercart, this is short for undercarraige and I am refering
to the undercarraige legs.
Yes I drilled on the correct marked points to line up with the existing holes
in the ply plate.
When I mounted the legs through the openings, I had to remove material from the bottom of the existing holes to allow the legs to fit correctly.
In fact you can see the extra removed area in the photos, as the legs are touching the lower fuselage sheeting.
This led me to believe that the legs had been moulded incorrectly.
I know you have to ask many questions, but to give you some backround, I have been
building for nearly 30 years which includes giant gas planes to turbine scale helis so
a small electric plane shouldn't be any trouble for me.
Look forward to your reply. Thanks again.
ID:	552407   Click image for larger version
