I used the OS46ax on mine and it's fine. However I did still needed quite a bit of weight for the nose. I have a 2400mah 4cell just aft of the nose gear former. I had thought about an OS61 for more power, I only used the 46 because I had it. I put a 10x8 pusher on the engine because that's what I could find. A 10x7 would be better or a little more power on the 10x8 would probably be just right. If I installed a slightly heavier engine like the 61 I could still move the battery forward of the former and get it to balance. The 46 moves it at 75 to 80mph not bad really. I toyed with the idea of a Wren44 which is only 6oz heavier than the OS46 (believe it or not) but this plane is really geared and designed for a 40 -60 pusher prop engine. As far as adding weight I believe it could handle an extra pound no problem. mine is 7.5lbs the landings are a breeze. Someone in the post was worried about getting the wing loading to high well, if this is a stepping stone for you (or anyone) into DF or turbine jets, your next step is sure to put you into a more heavily wing loaded plane anyway, might as well get used to it at $250 total instead of $5000.
ORIGINAL: gehr2box
Have one under construction. First thing I did was to get rid of that ugly green stripe on the nose and replace it with a red one (rustoleum matched the red canopy trim).
I have been debating motor options in my head. I'm a firm believer in light is better.
Retracts, while cool and speedy are extra weight and add reliability issues. Never mind the extra cost.
I have put large 2 strokes on small planes and the results (aside from thick winged 3d designs with 4stroke motors) have been unlimited vertical and poor low speed handling (due to the added weight of the bigger motor). More power does not appear to mean more speed. At least in the cases I have encountered.
For the price you can't beat the OS 46ax for power/weight. I was all set to buy it when I read about the OS 55ax. One ounce more weight then the 46 and 15% more power with the same mounting dimentions. There are better and more pwoerful motors to be had, but I am not looking for ultimate speed (and empty wallet), just a go fast fun flying cool looking jet wannabe.
I'll let you all know how it runs and flys.
