RCU Forums - View Single Post - Epoxy Mold Making
Old 11-01-2006 | 10:36 AM
j.duncker's Avatar
j.duncker
Default RE: Epoxy Mold Making
There is no simple 'right' answer to this.
A mould that must be stable and rigid eg. a wing will need more layup and external bracing than a canopy.
Moulds that SPLIT will need planning and usually benefit from the incorporation of a frame.
For a 40 inch long fuselage I used a 2" angle iron frame with welded corners on both sides with dowel bolts to ensure alignment and kept adding glasscloth till it was about 1/4 inch thick.
Here is a guide to producing a simple cowl mould. http://www.fibretechgb.co.uk/TipGlsFbrMld.htm
If you want to do something more complex a good library should provide a book The Glass-fibre Handbook by R. H Warring is a good starter.
