RE: RUSTLER STEERING
it all depends on the slop in your steering linkags and your transmitter turning. Generally if you want to go fast and straight toe the wheels out just a little bit (3 degrees max) conversly if you want to do cornering toe in up to 3 degrees. then while running straight adjust your steering center point on your radio
