Nope, I used the recesses but that is a good point. I hate to stand there and check them at the store but that is better than the alternative.
ORIGINAL: MJD
With APC, yes. Just a question though - is your balancer centering the prop via the molded recesses in the hub, or the drilled through hole? Those drilled holes are a sore point, they are all over the freakin' map and should never be trusted.
MJD
