RE: CMPro Christen eagle
Well,
You are absolutely right what you wrote at the end of the clip.I"m sorry but the truth is, the Eagle is not so forgiving like the Stearman but you will be do it. Just take care,don"t pull hard the elevator at slow speed, the eagle has a relativly high take off speed.Until you reach it, it is essential to use the elevator to hold the tail parallel with the ground with the use of a small amount of elevator and use the rudder countersteer if needed.On the video it was obvious that it t was your 1st biplane.Good luck with the Eagle.You will love it.So much fun for this price.
George
