RE: CMPro Christen eagle
Nice finishing Lou, I hope past experience with your Stearman will you help fly the Eagle like an eagle.
My canopy came clear of origin, did you die yours in black? how did you do?
It was more than a year somebody was asking advice for the powerplant, I decided for best deal betwen price and weight on gasoline power, so I put a CrrCpro 45 cc (2.4 cu in) engine and still with this 1680 grams (3.8 lb) ballast in the nose the plane´s CG was a little aft!! see engine at: [link]http://www.rcuniverse.com/forum/m_3186031/mpage_39/key_/tm.htm#[/link]
However, I´ve flown it two times succesfully...
My eagle will be flying again once a glitching servo problem be solved, I´ve browsed the web reading and looking for buffered leads, filters, noise traps, opto isolators, it was driving me nut but finally I knew my Futaba R127DP 7ch Rx is unable to drive the current pulses from the Hobbico CS-70 high torque tail servos.
