You can close the throttle to the point the engine stops due to lack of air.
I would not run a fuel filter in a normally aspirated glow engine.
ORIGINAL: pghmike
if you do run a filter...how do you pinch line to cut off engine? is this the only way used to stop engine other than running it copletely out of fuel?
