Fuel Filter??
i run one half way between the tank and the engine on my savage, it weighs next to nothing and it stops your engine pulling any grit from the fuel tank
if you do run a filter...how do you pinch line to cut off engine? is this the only way used to stop engine other than running it copletely out of fuel?
ORIGINAL: pghmike
I also just filter the fuel before it goes into the tank.
My Feedback: (16)
GA
You can close the throttle to the point the engine stops due to lack of air.
I would not run a fuel filter in a normally aspirated glow engine.
ORIGINAL: pghmike
AZ
I run filters out of my can and also to the carb.. and on my YS's I use one on the press.
side also.. It works great for me.. It may be overkill... But, no problems to date..
As said above, adjust your throttle/linkage so as to kill the engine with the trim or kill
switch from your radio..
CA
While I am quite new to rc flying I have a lot of experience with race cars (real ones) and have the following comment:
There is no such thing as overkill. What can go wrong will. Filtering at the closest point to where the failure will hurt the most is always a good idea. That point is where a failure in flight will cost you the plane and possibly the motor as well. Filtering out of the can is a great idea, but cannot stop problems from contaminants that have crept into the tank or line. While that might seem a low probability, any time you pull a line or open the tank for any reason you are risking it. And there are additional possibilities of contamination from tank or cap (plastic) detrioration or foriegn particles that were there to begin with and were not dislodged when the tank was cleaned out prior to installation in the plane (you all DO flush out the tank before installing it don't you? Or do you assume it came from the factory and is brand new so it must be clean?).
This hobby is not cheap and there are so many ways to create failures (other than my own lack of skill and experience) that I think filtering at the plane is more critical than doing it out of the can...but ideally I would do both (although I have not yet followed that part of my own advice I will on the next Tower order).
Airplanes normally are not run in the same environment as RC cars so there is some difference.
While you can put a filter on a plane, you can also keep the tank from getting dirty in the first place and avoid the filter on the plane altogether.
VA
I'm going to side with tessmar on this one. I'm one of those anal people who use a filter as a clunk in my fuel jug, a filter in the line on the jug, and a filter about an inch before the carb. I guess you'd call that triple filtered.
Oh and for what it's worth, I use one on my muffler pressure line too. It's not hard to imagine unwanted sludge making it's way into the fuel tank through the exhaust pressure line. Of course, with this many opportunities for failure, I have to make sure I backflush them from time to time to keep every thing free flowing.
My Feedback: (12)
And I'm going to side with Ken.
I've been at this for a while with both planes and boats. Occasionally I've tried running fuel filters and I've actually had more unexplained problems with them than without. Since I adhere to the K.I.S.S. philosophy, I've concluded that filters just complicate things. Practice good sanitation when fueling and I think filters are pretty much not needed.
The K.I.S.S. principle is good but where do you draw the line? The simplest of course is no filters at all. Anywhere. I've been guilty of doing that but only on a test stand, they don't crash very often if the engine suddenly stops
. In a model I'll always use an inline filter as a last line of defence but not a takeapart type because they have a chance of leaking. The only one I use is the Sullivan Cr*p Trap with it's double filter. You can filter your fuel as much as you like before it gets into the tank but what happens when a bit of carbon from the muffler gets in there through the pressure line? I go by the K.I.R.S.S. principle....keep it Reasonably simple...
