RCU Forums - View Single Post - Starting at Vacuum Bagging
Old 11-05-2006 | 06:19 PM
flyintexan's Avatar
flyintexan
Default RE: Starting at Vacuum Bagging
Matt,
In your words.....
"I started using 1/4"x1/8" carbon tubing as the aileron horn mount several years ago and have been very pleased with the result. The hole for the horn is already there and perfectly aligned. I use 6-32 bolts for horns (normally not the hardened variety); never use all-thread in this critical application. Vibration will fatigue all thread. If electric power, then not a problem. "
Can you elaborate on this? Sounds very interesting.
Mark
