How about a little love for the larger models? One common thing I see is 10/15s setups and I myself plan on a 10s. Problem is, there is no possible way to get up this high without buying at least 3 units of some type from you. The most cells that can be obtained is 4 to a kit which would mean significant labor, and 3s is the highest series battery pack meaning the cost would quickly climb and placement would be complicated. Another thing is the awesome charge times are meaningless using any stock offering of yours if your using a large number of cells. And going 10s2p would be even worse that just twice 10s1p unless you made your own pack(s).
These cells are sounding so appealing though that I will find a source and use these as a reason to learn to make my own packs. Two 10s1p packs with Powerpole connectors, here I come.
