RE: Lanier Ultimate Pitts finished
Ok, I maidened the plane this weekend! I had some difficulties getting the engine started (had to hand crank it because my glow starter just wasn't up to the task), and the maiden was done with the cowl off. I was running a 20 inch prop on the G38 and the landing gear barely gave enough distance (I was mowing the grass on takeoff!). Well, after a few practice run ups, I was able to take off at half throttle (with authority I might add). The plane needed a little trim, and I didn't want to put much stress on the plane for the first few flights due to the engine being brand new, and my first heavy plane. Even at half throttle, the plane was pretty fast!!! I landed the plane at a walking pace....she's a beauty to land...no bad tendencies at all...the landing gear strained when she touched down, but didn't bend much.....I checked the plane for any loose hardware and then took some pictures. BTW it flew GREAT at the 13.5 weight (just make sure you have your COG correct!)
OH yes, I had to get my girlfriend to pose with the plane!
Here are some pictures:
