RE: dual servo setup for split elevator / jr 2610
Thanks Danny, So does that mean I dont mix anything in mix 1 and only use mix 4? I understand that the second servo will then be placed in the gear port of the receiver, and can you still set the trim and reverse that servo if need be?
Once again thanks for your help.
Regards
Jason
