RE: HET RC Super Sniper Thrust Pipe Question
Go to staples and get a piece of laminate. They can make it for you for 3.00 dollars. Use clear storage tape to hold it together. Use the orginal paper thrust tube for your epoxy mix or throw away. I have a really nice stup if you are interested for that jet. Motor and fan with esc and li-po battery. 500.00 dollars worth of electronics for 300.00 if you are interested. Kontronic 480-42 motor, CC Phoenix 60 ESC, Wemotec fan and a 11.1v 4200mah 3s2p battery. Speeds are over 125 mph with this setup.
