RE: SolidWorks Modeling Methods
Thank you all for the help.
I have another question for the men that know how.
If I open a new empty assy. drawing. How do I locate a part to a particular location. For example if I want the parts origin to coincide with the assy origin, or be at a particular place in space relavent to the assy origin. The MOVE function does not seam to give me the required results.
The other thing that I have not figured out is, if I have a model for example a fuselage, how can I get the cross sections at fixed points. In other words I want to draw formers for the fuselage. Can it be done, or must you use formers to model the fuselage in the first place?
Once again, thank you for your help.
Regards,
Dale
