RE: WHAT'S WRONG WITH NITROPLANES.COM?
I was a bit taken back when I first saw the manual on my first NP ARF...
I put the box away and built two other ARF planes first from different vendors.
Then I built the NP ARF (an Ultimate 40s)... thanks to a few suggestions here, I had no problems with it, and by that time about the only things I needed was a basic layout (what goes where) and the C.G. figures.
For anyone considering a NP plane, be forewarned that you SHOULD have prior experience with building ARF kits
first as the manuals are not the step by step guides that you may see with other planes.
They are pictoral walk throughts.
On the CMP kits that Nitroplanes (and many others) sell, the manuals (what manuals?) is a rolled sheet with a blow up diagram of the plane.
THAT's IT!
If you can't deal with this, try something else first and save your own sanity and frustration.
