RE: Fliton Rogue undercart problem.
I appreciate your comments on the holes in the mounting plate being drilled in the
wrong place, however this doesn't affect the camber on the wheels as the legs are screwed properly to the plate.
I have studied photos of other Rogues including the RCUniverse review and your own website and I
can see the problem.
If you look at the photos of mine from the front, you can see there is an inward curve on the legs(not the sweepback),
whereas the other Rogues have straight legs.
I have got round this by heating up the legs and gently straightening them which has put the wheels at the correct angle,
while still retaining the sweep back.
This isn't a perfect fix as I don't know if the legs will be weakend.
A better resolve would be a pair of correctly moulded legs!![>:]
I will be test flying it this weekend and I'm hoping the flight performance will make up for this niggly problem.
